Guest jimmyd17
hi d3_L3ThAL,
i won't be selling the car with a RWC.. as for things it will need to pass one i have found that the front discs may need replacing although the brakes themselves work fine.. pads have plenty of meat on them. front struts are a bit 'spongy'.. not sure if they will be required or not. rear struts are very good and seem like they have been replaced. all the lights, wipers and all those functions work properly. there is some rust on the botton of the right rear guard, but im not sure if that is an issue with a RWC. the engine runs well and the whole driveline has no faults.
i hope that answers your question.
https://www.sau.com.au/forums/topic/41190-tf-cortina-wagon/#findComment-845481
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
