Hey Guys, I'm new here so be nice please lol. Only just bought the 34 about a month ago.
What I have is what I believe is an R34 Nismo Front Lip and Side Skirts.
Stupid me went drifting on Friday Night at Queensland Raceway and slightly damaged the front lip!
So I figured I'd be better off selling it before I completely break it!
No idea what these are worth, but I'm just throwing up a price at $500,
happy to consider all offers, price is just there to start :)
Also, will consider swaps for some parts..
I'm looking at getting an LSD, coilovers, strut braces etc, can swing cash your way if required.
I have yet to remove it from the car and confirm whether it's guinine or not,
It is however fiberglass so not sure if that says anything?
Located Brisbane Queensland and would rather not ship/post.
Can contact me on here, or phone: 0411 158 170
PS: If I'm completely wrong about the brand, please correct me.. I'm new to skylines!
Pics!
Edited by Vladimir
https://www.sau.com.au/forums/topic/413632-r34-nismo-front-lip-and-side-skirts/
Not to sure why a fresh import would have aussie parts on it :wacko: ?
But hey, ya never know! If it turns out it is for some weird reason, will drop price.. lol.
Edited by Vladimir
OK, so had a look at Viva Garage.. seem's like that's what I got!
(very bizare as to why a jap import would have aussie aftermarket parts)
I will double check condition of skirts and front lip some more tomorrow,
and also confirm 100% if they have any markings etc for brands.
Thanks for the info guys!
OK! Sussed it out, both fiberglass!
Front lip is $100 ono
Skirts are $150.. Excellent condition, and seem to be made of a higher quality fiberglass compund!
Don't really wanna go lower on the skirts, and may consider a little less on front lip.
Not in any rush to sell, just taking them off this weekend cause I don't wanna ruin the lip any further and don't wanna break the skirts.
Might repair lip if it sits long enough..
Edited by Vladimir
Will take $50 for front lip.. just realised it's in pretty dodge condition haha!
Skirts sold pending payment agreement!
The band aid is covering some of the damage which shows through on the opposite side..
http://imgur.com/a/SlZFL#0
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
