I've got a problem with one of my headlights (RHS) and hopefully someone on here can point me in the right direction.
Just recently the light stopped working. I pulled the bulb out and gave everything around that area a few soft taps. Then it began working for about one day and now it has stopped again.
I've switched ballasts over and bulbs and all seem to be working fine. From what I can see it is the below pictured cable and box that seems to be the problem. This goes through the actual headlight connecting the ballast to the actual bulb.
Can anyone tell me exactly what this box does and where I can find a replacement? The headlights are aftermarket.
https://www.sau.com.au/forums/topic/417763-v35-headlight-problem-help/
That's a CAN BUS error cancelling unit.
CAN BUS is a communication system between multiple electrical sub-systems. It is commonly found on lots of European cars and ours too. In this instance, when you install aftermarket HID's it freaks out the CAN BUS into thinking you have a blown bulb and you get a 'light out' error. So they install these inline and it 'convinces the CANBUS that everything is fine - as it is.
You can buy replacements like this:
http://www.hidlighti..._De-Coders.html
But given it's probably a cheap kit to start with, you'd probably better off just buying a new kit for as much as you want to spend (i've run $40 kits in fog lights on another car before with no ill effect) and you'll have new components because odds are if this one fails, the other won't be far behind.
Edited by SMOKEYC34
Thankyou very much for the detailed reply mate. I was having a look through my spare parts and I came across a cable like the one pictured below (ignore the ballast).
I connected this and it made the bulb work but was giving off a buzzing sound. Would I be able to use this for now or do you think it would cause some damage not having the CAN BUS unit there?
http://www.oemxenonshop.com/OEM-Xenon-Headlights-Parts/Infiniti-G35-D2S-Ballast.jpg
Can you point me in the right direction for a complete kit to suit what I need? Just in case the other side goes..
if it works you will be sweet. HID's often make a noise, I wouldnt worry about it. The error canceller is just a big resistor at the end of the day.
For a replacement, if you want to do it on the cheap, just pick anything off eBay - i'm sure they're all same-factory-different-door anyway. Like i said, i've run $40 cheapies before with no ill effect. With the cheap ones though, you will find that they have longer startup times, the colours can be different between the two globes due to low quality control of salts in the globes, and they'll start to lose output and colour (get bluer, then purple) before probably crapping out in 18months time. But if that's cool with you, then I wouldn't advise against it. Just stick to 5000k or below. Anything higher you lose light output significantly, and with lower quality kits thats probably going to emphasise the loss.
If you want to spend a little more, bang for your buck I'd recommend the Morimoto Digital kit from theretrofitsoure.com - they're quality digital ballasts (nice and compact) and quality output globes. Go for a 4300k (OEM colour white/yellow) or a 5000k (white/blue tinge). They will give you excellent light output and last much longer.
Thanks again mate, if you're sure it won't blow the bulb or something like that I will just go ahead and use the older cable with the CAN BUS unit until I find a new one.
I know they never made this noise before which is why I was a bit worried about using it that's all.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
