Hi All
I have the following for sale:
1. Work XT7 18x9.5 in silver with allot of scrapes and chips, tyres need replacing - $1000 (TBC)
2. JJR 40mm Alloy Radiator for R33 GTR 6 months old - $250
3. Arm rest console for R33 - $40
4. Dash surround for R33 series 1 - $20
5. R33 boot lid in white - $100
6. R33 stealth/drift wing brand new (unpainted) - $250
or take both boot lid and wing for $300
Pics will be uploaded very soon.
Located Ashfield NSW.
Thanks
Jay
https://www.sau.com.au/forums/topic/418215-r33-bits/
