Up for sale is my very clean S13! Served me well for a long time but Id like a change. I have alot of receipts for this car for alot of the work done to the car. Its probably one of the cleanest Silvia S13's out there.. it'll be sad to see it go.
Drives perfectly, its been my daily for a long time going to and from work but lately I rarely drive it. Always been garaged and serviced every 5000km. It has relatively low k's for its age (183 000km) and you will see upon inspection its been well taken care of all its life. Always used Shell 98 V-Power.
Only bad points about the car would be that the left indicator has a broken bracket, sits fine its just cable tied.
I'll consider swaps only if cash my way. Looking for a Skyline, 180sx etc or similar.
Please text me, no PMs or calls. Its just easier to keep track.
0402 832 three seven three
Located in Baulkham Hills, NSW.
PHOTOS: http://www.gumtree.com.au/s-ad/baulkham-hills/cars-vans-utes/1993-nissan-silvia-s13-sr20det-/1034718621
ENGINE/DRIVETRAIN:
SR20DET Redtop (factory)
Manual 5 speed gearbox (factory)
Hybid Front mount intercooler
Stainless steel dump pipe
High flow catalytic converter
Rare Jasma Catback exhaust (quiet/legal)
Turbosmart eStreet electronic boost controller
Exedy Heavy Duty clutch
New gearbox shifter bush
Aluminium overflow tank
Limited Slip Diff (Viscous)
HANDLING:
Cusco Zero Coilovers with cambertops
Nismo Aluminium Strut front strut bar
Rear strut bar
Front Whiteline swaybar
Rear R32 GTR sway bar
Adjustable camber arms
Adjustable tension arms
Slotted brake rotors
EXTERIOR:
Factory paint in mint condition
Rolled guards
Newly purchased "SILVIA" rear badge
J's/Brick Headlights
XXR002 wheels (15x8 0 offset)
Stock gearknob, seats, untouched dash etc
INTERIOR:
Alpine CDE-100 headunit
JBL Rear speakers and Pioneer fronts
Digital Climate control
Turbo timer
Personal 350MM leather steering wheel (genuine)
R32 GTR din gauges (volts, oil temp, boost)
OEM factory front and rear floor mats
  • Like 1
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
