Time has come to sell my daily driven Nissan Skyline. It has been a very reliable, comfortable and economical just as expected. This particular model has the beige semi-leather trim. This car is also fitted with a very rare factory aero body kit alongside with a factory option sunroof. It gets 500kms on a full tank, is super comfortable and no other car i have driven is as spacious as this. The car is equipped with full power windows, power reclinable front seats and reclinable rear seats which is amazing for a car from this year model to have. It has a factory fitted BOSE sub and amp so the sound quality of the music is amazing. The car has recently been fully serviced including oil,oil filter, platinum spark plugs, air filter, brand new brakes front and rear. I also have a new fuel filter waiting to go in. It has 4 brand new tyres fitted. The bad points are that the paint has a few scratches here and there for its age but being a silver car they are not noticeable unless up close. Secondly the ac needs to be regassed but i havent gotten around to doing it because its winter and i dont use the ac. The heater works fine. The car can be viewed anytime and is joy to drive. $8500 neg
https://www.sau.com.au/forums/topic/458630-2001-skyline-v35-syd-85k/
