Deatschwerks 440cc Injectors x 6 - $350 can include stock fuel rail if needed. No resistor pack required to run, plug & play.
Installed new and used for approximately 3000km of street driving. Removed due to upgrade to RB25.
RRP $460AUD + post
Wiring Specialties RB20 Coilpack loom - $100
RRP $150AUD
R32 Fixed back Bride Rail (Drivers side)- $100
2 piece rail, was fitted to Bride EXAS. Will confirm part number later.
APexi Active Tail Silencer - suit 90mm muffler tips $200
Test fitted and started car once with it on in garage, never driven with. Comes with Box and instructions.
RRP $275AUD + Post
Pickup Burwood, Vic or can post items at buyer expense.
May consider swaps with cash adjustment for good condition R32Type M sideskirts.
Contact via PM
Edited by Frushlife
  • 3 weeks later...
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
