Was just wondering whether anyone has purchased one of these warranties particularly where they imported the car themselves or bought privately.
Geoff Risbey at Prestige Motorsport has recommended them and it costs around $875 for 3 year warranty on any car, although you can purchase cheaper ones or for a lesser period. Details are in HPI No 25 pg 49 or their website http://www.cargear.com.au.
I have been thinking of doing this once my car is complied and registered but would like others thoughts.
Cheers, Al
https://www.sau.com.au/forums/topic/5242-cargear-warranties/
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
