sorry i dont sell to inbreeds...  :sperm:
This is very offensive to me and i will be contacting a moderator to sort this out, it's people like you that give skyline/import drivers a bad name, you are so immature and childish and you behave like a three year old.
yeah.. one of the moderators is probably one of your inbreed relatives.. :upurs:
Yeah ya mum's my inbred relative, didn't she tell you that while you were humping her last night?
um.. nice to know.. but my mum's past away.. nice to know you like your women old.. and dead!.. mr ***acarcass.. :jawa:
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
