Unfortunately I never got the chance to put this on my car and now i need to sell : (. On the previous owners car it only ran on 10psi and he sold it to me before he actually got a chance to get a decent tune, it was in his car for about a month.
I bought it with a .87 exhaust housing, but have since changed it to a smaller .64 exhaust housing for less lag as I was planning to put it on an SR20DET engine. The turbo also comes with a custom made low mount manifold(For SR20DET), Trust 45mm external wastegate, and custom dump pipe in which the wastegate can be vented back. The manifold also has mounts welded on for a heat shield.
A very mint turbo that is capable for some very decent power!!
pics will be up as soon as i take some. Can either post up, PM or email me at [email protected] for anymore questions.
Price: $4200 negotiable
https://www.sau.com.au/forums/topic/71493-hks-2835r/
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
