new skyline
well I had a mildly worked VL and went to a R33 GTST with full exhaust and air pod..... no comparison.... the skyline is better in every way... I have absolutely no regrets in buying my line.... apart from now wanting to do soo much to it because I like it soo much :D
https://www.sau.com.au/forums/topic/9131-new-skyline/page/2/#findComment-137879
I have a full exhaust. The front pipe and dump where made up by quick fit, no sepparate wastegate pipe. The rest of the exhaust is FGK (fitsubo giken) Super Ti series? very quiet (more quiet than stock at low rpm).
If you want to do the exhaust in bits to save money you could just replace the front muffler (get a straight through hot dog, not stainless about $100) and do the dump pipe ($400 max I paid for mine). you can get the rear stainless muffler later (for show) and do the 3 inch pipe work between them later on.
you will still spend close to $1000 but in bits.
https://www.sau.com.au/forums/topic/9131-new-skyline/page/2/#findComment-137939
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
