Item:PSP V2.0 Value Pack+ 2 GAMES + 1 UMD + ACCESSORIES
Item Condition: As New, No scatches/marks
Reason for Selling: Bought it thinking i'd use it, obviously not
Price and Payment Conditions: looking at $400 + delivery (if needed) for the whole lot (boxes included). will do COD
Extra Info: Ive only had this psp for about a month and its probly seen only about 5hours of playtime. things included are
- PSP Value Pack (upgraded software to 2.0 and everything that comes in the box)
- FIFA 2006 (US version)
- Untold Legends: Brotherhood of the blade (AUS version)
- Spiderman 2 UMD
- Comes with a few accessories from the essentials pack (carrybag, earphones, handgrip etc)
- Also comes with an extra Scandisk 512MB memory card
- USB data cable
so all up together if u were to buy these ur looking at about 800bux brand new.. so come grab urself a bargain.
Contact Details: please PM me ur interest,
Edited by hanyou
https://www.sau.com.au/forums/topic/94467-psp-package/
