Hi All,
With all the interest shown and PM's received from SAU members, the guys from Platinum Performance Parts and Imports have offered to continue their sale on intercoolers for all SAU members. I have attached photos from one of our members installs, as well as the hybrid brochure.
Group buy start date: 07/02/06
Group buy end date: 31/03/06
Location:[/b] 17/287 Victoria Road, Rydalmere 2116. Sydney, NSW.
What you get: All R32, R33 and R34 Kits are the same price.
All kits come with Silicon hoses, new hybrid designed heavy duty clamps,
chrome piping and instructions and all bracketing needed. All comes brand
new in wrapping and boxes.
Price: For Intercooler and piping $680
For Intercooler and piping + Installation $880
Website: http://www.platinumppi.com/
Bookings: Call Daniel on 0411101737 and mention you are calling about the SAU group buy, he will organise a date and time for install.
Edited by RYD11R
https://www.sau.com.au/forums/topic/104825-r32-r33-r34-hybrid-gt-coolers/
Finally its in...... Daniel did an excellent job, no issues, big difference in response and power........ I LOVE IT.......
Recomend to all other owners interested in a very, very nice upgrade...... my pics attached
Hi bro,
Do you install s15 aswell and if you do, how much will it cost?
Hey man,
I personally don't install the systems, but call Daniel and he will beat any price u can find.
Edited by RYD11R
  • 3 weeks later...
Hey guys i believe the pipes are light weight aluminum and coated in a chrome finish just for your information.
And yes S15 kits available they are $930 installed as this takes quite a bit longer to install
Thanks for that man.....
hey i was just wondering if i buy the cooler now but get it installed later will it still cost around the same. reason being car is not ready yet but dont want to miss out on this wonderful group buy.
cheers,
dom
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
