Hey everyone
Im from Melbourne, Vic. And have recently purchaced heaps of upgrade performance part for my R33 Gtst. One of which is a Nitrous Kit.
Does anyone know the legal restrictions to these?
for example FINES, REGULATIONS, ETC ETC
Cheers
https://www.sau.com.au/forums/topic/106301-nos/
Its illegal for street use.
That simple.
If you take the bottle out, then your legal for street, but then its of no use without gas :)
Fines would be high, plus then you get defected its all the RWC hassles and more costs to remove etc etc.
https://www.sau.com.au/forums/topic/106301-nos/#findComment-1960503
hide it well.
i did have a nitro setup before i did my turbo and cooler etc, and i hid the bottle in the place where the useless space saver spare wheel went... the cops never looked there, once they saw how much sound crap was in there it deturred them. its a a long run of hose, but hey, youd probably never get dun 4 it.... NOT SAYING THAT I CONDONE DOING ILLEGAL SHIT...lol
https://www.sau.com.au/forums/topic/106301-nos/#findComment-1960728
illegal shit... not at all... lol
I've actually built a custom boot setup so i was thinking about storing it next to the battery in the back of my r33 gtst. Theres heaps of room on the right side. (batteries on the left)
Cheers
https://www.sau.com.au/forums/topic/106301-nos/#findComment-1961141
Cops arent stupid these days, they know what NOS injection/extra solenoids are.
Last time i heard of someone busted with NOS here in Vic.
That had to tow the car home from where they were pulled over and wasnt driveable until engineer cleared the car for correct removal of all the gear
its your own risk
https://www.sau.com.au/forums/topic/106301-nos/#findComment-1961183
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
