NOW SOLD
Item: RB20DET. Block, Pistons, Head, etc... all together... No coilpacks, etc. Just the bare metal parts...
There is from what we can tell something wrong with a cylinder as it developed a miss.
Someone make and offer and take it away please.
Troy
NOW SOLD
https://www.sau.com.au/forums/topic/106666-sold/
I'd be interested in the head if you'd un bolt it for me and freight it to Cairns. I'd pay for the entire engine of course and you can still flog the rest or dump it.
What do you think? Oh crap! its an old post.... bet its long gone...
Ian
Edited by GTST4Newbie
https://www.sau.com.au/forums/topic/106666-sold/#findComment-1970342
Ian
Its still there...
I wont be doing somehting like that, sorry... unless you want to arrange to have it all picked up as a whole.
Troy
https://www.sau.com.au/forums/topic/106666-sold/#findComment-1970824
Motor is in campbelfield. Not much to see really..
Troy
Campbellfield? that's around the corner i'll come and pick it up this w/e :P PM me your mobile # and I'll head out if you still have it.
Michael
https://www.sau.com.au/forums/topic/106666-sold/#findComment-1977976
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
