Hi all, I think this is a very good topic if people can give some input.
Do you know the amount of total timing you are running at full boost and what power you are making?
eg : R33 GTR 18psi / 20degress timing. 270rwkw.
I am triing to work out if I drop some timing and run more boost. I am also trying to work out where some of these huge power figures are coming from? I have raced a few big hp cars ( over 300rwkw with proof) and still have the faster car. ( I don't have any torque figures).
Theory says more timing the better and the sign of a well built motor is being able to run heaps of timing.
I have seen plenty of cars on dyno's run a big figure once then every other run get's lower and lower as heat soaks in, showing they are really at the edge.
I know all my temps - exhaust,inlet, water,oil, - hardly break a sweat at my current tune after 6 back to back power runs. Maybe Im not pushing it hard enough?
Or is this just a case of dyno reading wars.
What do you think?
Please, lets get some constructive info going.
https://www.sau.com.au/forums/topic/107053-boost-versus-timing/
hello
Many people have different views
Many tuners have different views
Depending on the application of what you want changes how much timing you run.
If you are building a street car you will need to run a safe timing of close to 20 degrees/18psi due to standard fuels not always being consitant.I have had my skyline on the dyno many times and have found that running to much timing can be good but at times bad as well as i have got a bad batch of fuel.
When you go racing on c16 fuel etc you can run as much timing as you can as long as your engine isnt knocking.You are better off watching your knock sensors and checking timing on the dyno then on the street.Air temps of the motor make a big difference on the ability to make a motor run alot of timing too.i found by runing a larger cooler in a street car then what was recommended made me gain more power.
More timing will give you more torque but there are other aspects you will need to consider like aftermarket cams can run more timing then most standard cams.
I pefer to have a little bit more timing then more boost just because in my own view runing less boost and more timing in your motor to a safe limit and making more power and torque seems to be safer thats my view anyway but everyone has there own views and beliefs.
Everything varys and engines are all different
you will need to put it on a dyno and experiment.I am and it pays off
Edited by LNEMUP498HP
boost does not make power, airflow does. increase airflow and you'll make more power. adding more boost "or pressure" simply takes away volume and adds more heat. which is the opposite of making more power. this is of course when you go out of the efficiency map of the turbocharger.
so it depends on your turbochargers compressor map, the map may give you that 24psi is still in effiency whereas on another turbocharger over 14psi is off the map and thus you just dial in more and more heat
Maximum power at one rpm point is a USELESS number, how fast a car is depends on its average power over the used rpm range. Get your dyno graph and the 300+rwkw dyno graph and compare the average power, say 4,000 rpm to 7,500 rpm in 500 rpm increments. The faster car always has the higher average power.
:) cheers :)
mmm.....
All very valid points,
Does anybody out there have compressor maps for GT2560-5 garret turbos ( there should be these are very popular lately)
I should have clarified PUMP FUEL 98.
BUT Does anybody out there want to contribute their figures and set up if they know them.
thanks guys for your input. :(
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
