1. Start and end date for the group buy
now till 24march 06
2. Clear details of the product/s on offer
4MR loop sling max load 6000kg greenish yellow colour to go with the weight code
3. The price being offered and if possible the normal RRP
my price $25 RRP $250 :ohmy:
4. The company that is supplying the products for the group buy
me
5. Associated costs for delivery what ever aus post costs
7. Where possible, please include a photo of the goods being offered
pics up soon
i need five people for this to go ahead these are great for any lifting applications they wont scrach your items
Edited by xr8eater
https://www.sau.com.au/forums/topic/107790-endless-slings-6000kg/
awsome three left
and for being the first one grandmasterb gets one extra for free
cheers
these are flying off the shelf on ebay for $50 but it's a special price of $25 for sau members
Edited by xr8eater
awsome three left
cheers
well i better make it an even four then mate (dont like odd numbers :kiss: )
So i'll take 3 and the free one :D
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
