Near new,
Has small scrath on top.
Your music in your phone — W800i Walkman®
Have your music with you wherever you are. Just press the music button to start your in-phone music player, select your favourite song or playlist and enjoy. Getting your music into your mobile is easy – the W800i comes with music transfer software. Move the music from your CDs. Fast and easy. And, to introduce you to the Sony Ericsson Walkman® phone experience, there are six top music hits waiting for you in your W800i.
Easy imaging
The W800i is also a 2 megapixel digital camera with video recording capability. Save your images in the W800i image gallery or move them to a PC. Let your friends see what you see using picture and video messaging (MMS) phone-to-phone.
Store more
The W800i has plenty of memory inside for storing your favourite songs, images and video. And when you need to store more, use Memory Stick™ PRO Duo. In addition to the phone’s internal memory, you can have up to 1GB expandable memory. Thousands of images. Hundreds of songs. The supplied 512MB Memory Stick™ PRO Duo gives capacity for around 150 music tracks - or 10-15 full length CDs.
Enhance with accessories
A quality headset is included in the phone kit. To enhance your sound experience even further, connect your W800i to your stereo with the Music Cable MMC-60. Keep listening but never miss a call. Your music automatically stops when a call comes in.
Designed for use
The W800i never compromises on ease-of-use. Synchronise and transfer files rapidly with the Fast port connector. Go wireless - connect to other devices with Bluetooth™. Share with friends and family in seconds with QuickShare™.
Firmware has been upgraded to latest version.
Includes box, headset, data cable 512Mb mem stick duo and charger.
regretful sale
https://www.sau.com.au/forums/topic/108542-sony-ericcson-w800i/
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
