Selling the following parts of an RB26:
1/ Pair of used HKS 2540 turbos - bit of play, can be reco'd by GCG or Garrett or new CHRAs sourced from Japan - $1600 (rebuild approx $1,000)
2/ Pair of used HKS 272 duration cams w/adjustable cam gears - $800
3/ Pair of used HKS split dump pipes - $500
4/ Pair of used HKS exhaust manifolds w/cross over pipe - $1300
Will sell the lot as a package for $3500. Located in Sydney.
https://www.sau.com.au/forums/topic/108653-gt-r-hks-2540-package/
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
