what is the best exhaust? I don't think many people get chambered exhausts anymore.... there are many straight thru exhausts that are quiet on turbo cars.... not sure which ones though
i heard that hks, fujitsubo are very good.. but some others like buddyclub are loud ass.
https://www.sau.com.au/forums/topic/10972-exhausts/#findComment-181154
Doxx,
The guy who bought the Super Dragger off me said he needed two resonators to quieten it down. Otherwise the booming sound is enough to trigger all car alarms when you drive past.
So when you bought one, make sure you also get the middle pipe that comes with the resonator, otherwise, trying to fabricate a 3.75" pipe to suit your dragger might not give you the best result as getting the original HKS middle pipe.
Putting in resonator might decrease flow, but in terms of HP gain without resonator compared to the amount of cop attention you'll get... is it worth it? Unless you're going for the track all the time, you may not need it.
I got Trust system front pipe and cat-back. It seems to me that when I put in front pipe, it is not as loud as cat-back only. Maybe the way the gas flow from small pipe onto the big pipe creates a big noise at the cat before. Now with front pipe in, it may creates that noise right after the dump pipe, and by the time it reaches the back, that noise has been long way supressed in the piping.
That's just my theory.... Might worth considering getting a matching front pipe as well.
https://www.sau.com.au/forums/topic/10972-exhausts/#findComment-181710
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
