post-26465-1142758905.jpgpost-26465-1142758701.jpgpost-26465-1142758890.jpgpost-26465-1142758723.jpgpost-26465-1142758733.jpgpost-2292-1125290742.jpgpost-26465-1142758755.jpgpost-26465-1142758924.jpg
Got a R32 Skyline for sale as follows
NISSAN SKYLINE R32 GTS4 4WD TURBO
Climate Control
Power Steering
Air Conditioning
Moon Roof
Upgraded R33 Breaks and polished rims
Low km (90 000 km)
JVC CV Head Unit
4 door
Manual
THE CAR MUST SELL DUE TO GOING OVERSEAS, THIS VEHICLE IS A GREAT FAMILY CAR IT ALSO HAS GREAT POTENCIAL AND IS VERY RELIABLE. FIRST TO SEE WILL BUY.
This is a unmolested car and is in very good unmodified condition.
Price is $13000
0410607169
Sydney
Let me know what everyone thinks
CHEERS NICK
Edited by boggie23
https://www.sau.com.au/forums/topic/110246-skyline-for-sale/
I THINK YOU SHOULD CHANGE HEADING BE A LITTLE MORE SPECIC AND YOU MIGHT ATTRACT MORE INTREST
SKYLINE FOR SALE ON SKYLINES AUSTRALIA ISNT ALL THAT ATTRACTING.
JUST MY OPINION TRY CAR SALES IF U HAVENT
GOOD LUCK
when your on this page down near QUOTE you should have EDIT next to it click on it then change the title and then hit save down the bottom of the page hope this helps...
''im interested but dont have the cash right now.
mayb in a 2 months or so time. i have an auto ca 180 if ur interestd in a swap.''
Hey champ
yeh we will see how everything goes.
13000 is probably the limit. i dont think i can go under that.
so we will just see what happens.
anybody can come have a look and then we can arrange something.
had some offers but they where too low. might just have to wait and see.
are you around they sydney area shifty01
Edited by boggie23
It has been almost a month now and have not had anybody come and even look at the car. LOL
Tyre kickers are welcome lol.
Anybody want a rare GTS4???
Does anybody have any offers.
If the rego is renwed i wont be able to take offers.
So now is your chance everybody!
This is a great car and has been my daily driver for the last year. Never had any problems with it and being 4WD it has awsome traction.
I am leaving for overseas soon and would like it gone by then. If not i might have to sleep in parks instead of hotels. So please i dont want to get bumbed in Europe lol.
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
