Moving house in 5 weeks, garage is full of car crap, time to get rid of this stuff.
Firstly the original RB20DET engine from my a31 Cefiro. This was cooked pretty good when a radiator hose burst. Still was running but overheated after 10/15 minutes without fail. Compression test not pretty. Suit decent rebuild/spares.
Includes turbo, power steering pump, air con compressor, rusty old flywheel and clutch, alternator. Will seperate parts.
Loom and electronics can be provided or seperated. Pretty much entire entire loom minus afm from auto a31 cefiro including ECU. Never tested this, just swapped my old loom over. Includes ignitor chip, coilpacks, CAS, etc.
$300 for everything.
S13 subframe from my old 180sx. Straight as a die, complete except for toe rods. Includes hubs and studs. $100.
180sx tail lights from my old 180sx. Perfect condition, no scratches/cracks. $50 pair.
Complete rear brake setup from s13. Includes discs, calipers pads, and complete handbrake assembly and cable. Perhaps ideal for rear disc conversion on older car? $50 the lot. Alloy coolant temperature probe housing (on far right in red)$20
S13 front and some rear inner plastic guards. Good condition. $40 the lot SOLD
Heaps of misc trim, spares, etc. What you see is what you get. Free to good home(s). Will post if buyer pays postage. standard fee of $10 for such items, that way I might make $3 an item for my trouble. May or may not include free spiders from my shed. Vague descriptions of what is seen in each pic below.
Instrument surround, glovebox, interior trim, washer water bottle with filler neck, steering column trim all from s13.
Centre console, air con under dash ducting, interior trim, hacked r32 skyline airbox, castor rod.
Antenna mechanism, rear 180sx trim: speaker supports, etc. Misc induction system airboxes.
Dented sr20det sump, 180x rear speaker supports, myriad of engine bay supports and brackets I deemed 'too heavy', 5 bolt drive shaft good except dodgy thread on end, good but restrictive catalytic converter, airbox chambers, spare s13 rear hub with rooted wheel bearing.
s13 rear and drivers seats.
Please PM or email [email protected] for further enquiries. Located in Blue Mountains, 40 mins up from Penrith, NSW. Most things that aren't sold will simply be binned within the month.
Cheers,
Michael
Edited by l6a6w6s6
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
