hi guys ive taken the following parts off my r33 gts-t
1 Apexi Power FC AND Hand Controller - $800ono (upgrading to an AUTRONIC)
* 1 Apexi Power FC only ( no hand controller) - $500ono (pretty much SOLD to RT33)
* 1 Apexi AVCR (perfect condition) -$400ono SOLD!!!
* Top 1/2 of stock plenum and Throttle body- $90ono ( will seperate if both buyers are there)
* Assorted black and stainless steel piping (pics on request to make things easier) $POA
* Oil Catch Can- no breather on top- $10 SOLD!!!
* Stock fuel pressure regulator- $20
* Stock washer bottle with motor -$10
* HKS pod filter ( filter needs replacing)- $10
* 3" dump pipe ( rusty) $10 SOLD!!!( to mr g pretty much)
* 3.5" dump pipe ( bit rusty but mainly good)- $20
BOTH OFF TRUST TURBOS
* center muffler from a 3.5" system- $15
EOI: unsure yet whether to upgrade core size or not, but its a HYBRID (genuine bar and plate) 600x300x76- $350ono ( excellent condition!!!) handled 350rwkw with no problems at all
pics available for all parts (some today some tomorrow)
Cheers...Ben.
Edited by 2BNVS
https://www.sau.com.au/forums/topic/110948-power-fc-z32-afm-avcr/
new pics of some parts added
- some black and polished cooler piping- $POA
- gfb hybrid bov, bottom adapter- $10
- misc fuel lines from stock plenum set up- $poa
- screamer pipe off trust wastegate- $15
- support bar for bonnet latch- $10
- misc hoses- $5
Ben, is this the 3.5inch dump??? Let me know how much you want for this item you have listed. Im in wollongong 3 times a week for uni so ill prob come pick up if the price is what your after
http://image-cache.skylinesaustralia.com/f...-1143238094.jpg
POWER FC? without handcontroller!!!
is it still for sale?
and wat condition isit in?
come with everything to connect? and that is to hook it up to 95' R33, Gts-t manual!
and PIC plz,
[email protected]
thanks,
Edited by RBFIRE
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
