MAZDA RX7 Series 6
Manual 13b twinturbo
MAZDA RX7 SERIES 6 TWIN TURBO UPDATED 2002, PERSONAL IMPORT SO IT WAS BROUGHT DOWN BY THE OWNER FROM JAPAN. AUSTRALIAN COMPLIANCED IN 05 2001. CAR HAS REGISTRATION HISTORY IN VICTORIA AND NSW AND CAN BE REGISTERD IN ANY STATE IN VERY GOOD CONDITION ALL AROUND, BIGGEST HEAD TURNER ALWAYS STANDS OUT IN THE CROWD. HEAPS OF MONEY SPENT ON THIS CAR, IF YOUR AFTER A RX7 WITH NO HEADACHES THIS IS THE ONE. ANY TEST OR INSPECTIONS WELCOME. ON 89,897 KS.
INTERSTATE SHIPPING CAN BE ORGANISED PLEASE CONTACT ME FOR A PRICE FOR INTERSTATE SHIPPING
ASKING $29,900 MIGHT SWAP FOR SOMTHING THAT INTERESTED ME AND IF YOU WANT TO PAY ME ONTOP
CARS LOCATED IN MELBOURNE CALL ME 0401267277 IF I DONT PICKUP SMS ME ILL CALL YOU BACK
MECHANICAL: 5SPD MANUAL, FULL REBUILT ENGINE BY PROMAZ MELBOURNE, WITH RECEIPTS SPENT $6000 ON THE REBUILT NEW HOUSINGS SEALS ROTORS GASKETS THE LOT. SEALS STILL UNDER WARRANTY. RECO TURBOS NEW BATTERY, BRAKES, 5ZIGEN 3" EXHAUST. BRAND NEW EXEDY CLUTCH.
TRAVELLED 2000 KS AFTER REBUILT BASICALLY BRAND NEW ENGINE JUST RAN IN AND SERVICED, NEVER BEEN BOOSTED AFTER REBUILD, HARDLY GETS DRIVEN
EXTERIOR: SILVER METALIC PAINT IN VERY GOOD CONDITION WAS ALWAYS GARAGED UNTIL LAST MONTH,ORIGINAL MAZDA SERIES 8 FRONT BAR BRAND NEW LIGHTS, SPOILER, 2 MONTH OLD 19" RIMS
INTERIOR: VELOUR FRONT SEATS/. MOMO SHIFTER. BOOST, OIL TEMP, AIR FUEL RATION GUAGES ON THE PILLAR POD. MP3 HEAD UNIT, 800W AMP, 12" SUB, REAR SPLITS FRONT TWEETERS ALL PIONEER,
Asking Price: PRICE HAS BEEN DROPPED $29,900
very very keen mate...
my 33 should be sold next week will have the cash then...
keep you posted
thanks
no prolem, had a deposit on it but the guy couldnt come through with the finance, so it fell through
heya me mate wants to know if ya interested in a swap for his wrx?
its a 11sec car with full forged engine/ppg straight cut gearset n lots of other bits :)
crazy economy @ 10L/100KM
Edited by shy_s6
So what exactly is doen to it to make it a 2002 update?
My 320rwkw 1996 gts-t is up for sale, and was looking at getting a rx7 in a few years time, but would also consider a swap.
This is my forsale thread http://www.skylinesaustralia.com/forums/in...howtopic=111294
Let me know if interested.
sorry after owning a gts 33 and having alot of problems i wont be looking at geting another one, but yours is neat as you shouldnt have too much problem selling it good luck
shy_s6 what year wrx is it?
im also trying to sell me jeep, dunno if your interested in a trade :( would prefer with stock rims just for a lil price drop :) also wat sus is it running looks pretty low ;) im pretty keen wouldnt mind a s6 again :P
Edited by shy_s6
commodore? i cantell you sooo many commodores, what commodore?
Holden VR Commodore
Full VY GTS Bodykit
Full respray marone color
20" ACE Rims
HSV 185i V8
Yella Terra Roller Rockers
Worked Auto trans, 2500rpm high stall & strong chev gears
Cold Air Intake
High flow air filter
extractors into twin 2.5" cats then to single 3" pipe
Full spool 4:11 Diff
King Springs ultra low's
Tinted windows
Big Sterrio
Fully re-done interior (black leather)
Alarm system etc.
i got heaps of pics if you would like to see them
Edited by teazn_r33
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
