hks gt2530 turbo x 2 with actuators, t3 type.... in brisbane
for specs refer...
http://www.bd4s.com.au/hks%20turbo%20GT.htm
I bought and planned to use one for my ca18det but overseas plans have changed this. Ive being trying to sell the single with no serious interest, since then I have aquired the mated other to hopefully sell as a pair. Pic of second up soon.
$3400.00
cheeRS
glenn
https://www.sau.com.au/forums/topic/11801-hks-gt2530-x-2-pair-sold/
as far as im aware these come with only two different exhaust flanges, one being gt25 and the other being simply skyline type. This is how they are listed through the Bd4 site. I can measure the stud pattern if you would like confirmation on this.
For anyone curious I will separate as Ive only got the other to sell as a pair.
cheeRS
glenn
INASNT
yeah gtr. Im not up on skylines, i had assumed skyline meant all skyline... anyhow... the stud pattern is 40x73 and the flange is studed... ive not seen any skyline manifolds so dont know your options.. although have seen certain types that have had the exhaust manifold holes ovaled for fitment off different turbos.. not sure if this is an option for you... what stud pattern do you currently have??
cheeRS
glenn
Originally posted by ed
does this mean t3 flange?
hmm. i would be greatful if someone could clear this up for me as well... Ive had people say'oh its a t28 flange'??? whatever that is...none of this was a concern for me when i bought as i was going to fabricate a manifold to suit.
basically its only stated as..
Exhaust housing.
inlet flange : T3
outer flange : Internal - skyline type
* quote BD4's hks catalogue *
Predator666
I take it your cashflow hasnt improved then.. Save up for one.. :D
cheeRS
glenn
going down...
$3300.00
INASNT... any word on those dimensions?? just reading another thread where someone's saying that a single from a gtr pair of 2540's will bolt to a single manifold... :)
and ... to those who state they can buy one of these new for 2300..brand new.. :P good luck
cheeRS
glenn
Guest Crazy-Drift-Action
hi guys just to clear up yer that's correct there a (t2,t25,t28) rear housing size yer it's a bummer that it won't fit a normal gts-t (t03 studd) as it would go good. these in twin format though on a gtr go awsome and is a very good reliable setup for the money.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
