1990 Mazda Astina SP. 7 Month's Rego. 5 Speed Manual, 1.8L DOHC, Power windows, Power Steering, Power Sun Roof, Air Conditioning, Power Mirrors, 4 Wheel Disc Breaks.
Just replaced the motor - current motor has only done 93 800 KM. It's an import from Japan but it's exactly the same motor as the original. I have all the paperwork - done by Concord Parts Plus. The car itself has done 225 000 KM. The new engine was put in about 3 weeks ago from 12/02/2006.
PRICE IS WITHOUT THE WHEELS AND WITHOUT THE SYSTEM.
WHEELS AND SYSTEM DETAILS: Brand new 16" wheels bought 11/02/06 worth $750 with brand new silverstone low profile tyres worth $480 from Eagle Tyres - have receipts.
Panasonic MP3/WMA CD player. Response 6x9s top of the line 80w RMS in custom parcel shelf, with Response 4 x 130w RMS amp running a brand new Pioneer 12" sub as well - bought 09/02/06 - have receipts.
CAN SELL TOGETHER - WITH WHEELS AND SYSTEM FOR AN EXTRA $700
Car is currently insured with AAMI (22 Year Old Full License Driver) for $649 and is covered for $6300 comprehensive. Passed rego with no problems.
Contact: 0412 038 183 ask for Marko. Located in Ryde area in Sydney.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
