have you looked under the oil filler cap? check to see if there's any mayo type looking sttuf, which could indicate a blown head/head gasket etc. also check the hoses around the sprayed area for crack etc.
but as para said, give it a clean and see if it comes back.'
steve
p.s refer to the cum stains thread for cleaning
Edited by PHATR32
https://www.sau.com.au/forums/topic/121896-wtf-is-this/#findComment-2248220
steve
Hmm blown head, dont like the sound of that!!!
I havent cleaned it yet, its off the road until the new turbo goes on because it needs tuning and i cant afford to tune before AND after the turbo goes on :dry:
https://www.sau.com.au/forums/topic/121896-wtf-is-this/#findComment-2248356
well, check the oil cap anyways. and the radiator cap etc.
Yeh they are fine... might have to look further when i get it tuned
I really really hope head is fine, i was going to put metal head gasket in,
but thought i'd do that later when i rebuild it all.
thanks mate
https://www.sau.com.au/forums/topic/121896-wtf-is-this/#findComment-2248452
check the coolant lines that run through the throttle body, looks like one of them could be the culprit.
Cheers
Ill post another pic, where i think it could be coming from (just based on the directionality of the spray)
Its slightly greeny so i was thinking coolant
Anyway here is the pic
https://www.sau.com.au/forums/topic/121896-wtf-is-this/#findComment-2248510
I'm guessing its the air pressure release bolt (not sure about the formal name) for the cooling system. Not sure where it is on the RB25s but on the RB20 it is near there and I didn't tighten mine up properly when I flushed out the system and when it got hot you could see small drops of coolant leak out.
Check that along with the coolant lines running through the throttle body as someone else suggested.
https://www.sau.com.au/forums/topic/121896-wtf-is-this/#findComment-2248517
Thanks
ill check it out tomorrow
https://www.sau.com.au/forums/topic/121896-wtf-is-this/#findComment-2248527
ah thats a better pic. on the other pic it looked like mayo etc. forget the blown head gasket theory.
that looks like dried coolant, so yeah, defently check those spots with the arrows.
steve
Yay head is OK!!!
Yeh its like dried coolant, not spoof!!!!
https://www.sau.com.au/forums/topic/121896-wtf-is-this/#findComment-2248576
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy re
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
