For sale:
Two tone silver/grey 1985 rx7 13bt
Item Condition:
Engine
S4/5 13b turbo
Management
Microtech LTX8s
Internals
3mm apex seals
Modified oil galleries
Turbo porting
Exhaust porting
Induction
GT 35/40 turbo
Port matched series 5 inlet
2* Cosmo 12at (blue) injectors
2* S4 13bt injectors
Large custom intercooler
Stainless steel pipe work
Exhaust
3 inch stainless steel exhaust
45mm turbosmart wastegate
Accessories
Gilmer drive and belt
Turbosmart BOV
Autometer boost and oil gauges
Turbosmart boost controller
Braided oil lines
Polished oil catch can
Alloy surge tank
044 motorsport fuel pump
Desert cooler 4 core radiator
Power
295 rwhp, 13psi, Maztech dyno
Gearbox
Series 5 turbo with guru short shift kit
Flywheel
9 inch lightened
Clutch
Solid disc 4 puck
Custom 1 tonne pressure plate
Tailshaft
3 1/4 inch heavy duty
Diff.
Guru motorsport torsen, 4.11
Mazda 28 spline axles
Brakes
Standard
Front: Hawk pads
Rear: Bendix ultimate pads
Suspension
Pedders shocks and lowered springs
Whiteline front strut brace
Wheels
Rear: 17 inch simmons OM's 8 inch with 245 tyres
Front: 17 inch simmons OM's 7 inch with 205 tyres
Interior
Pretty much standard (excellent cond)
Stereo
JVC head unit
Front: Eclipse 5 1/4 inch 3 ways
Rear: Jaycar 6 inch 2 ways
Electrical
Boot mounted optima battery
Hidden and re-routed wiring
This car has been featured in Zoom, Killer conversions. Used to have the plates 'BUZZED'.
Price and price conditions:
$15k ono. May consider swap, or swap plus cash.
Vic Reg.
Pictures:
car0186yf.th.jpg 295 rwhp on 13psi (maztech)
car0196mi.th.jpg Previous owner had made 275 rwkw on 16psi (dyson)
Contact Details:
PM or contact (03)57286624 - 0428697601
Beechworth, NE Vic, near Albury/Wodonga
Here's another clip from when i took the car to the Wilby drags (1/8th mile), racing a WRX, R33, HSV.
It was my first (and only) time at the drags and this footage was from my first few races where i was still struggling to get off the line.
Wilby drags
Edited by jimtron4000
is there anything wrong with it?
How old is the engine?
Might be interested once i sell my gtst
Have you got a 1/4 mile time?
Robert
R32 GTSt For sale
http://www.skylinesaustralia.com/forums/in...howtopic=123582
C'mon! Very quick and neat car. Suit show, strip, track, street.
Made the Go-to-whoa finals at last years Springnats.
Try something different!
Nothing's wrong with it! Would benefit from a bit of a tune up (and more boost), but still runs well as is (minor idling issues). Engine's about 17000kms old. Still runs strong. Haven't taken it down the 1/4 mile but I would guess 12's as is. Potential for 11's.
I took the car to Heathcote yesterday. It was my first time down the quarter, but it wasn't the best introduction. I had alot of trouble with my clutch, with it either slipping badly or just not letting me get in or out of gears. Anyway, there were 2-3 runs where the clutch didn't stuff up too badly and i managed to run a [email protected], which i thought was alright considering. Another run I ran a [email protected] and my best 60ft was 1.75sec. I hope that with a new clutch and a bit more practice i could achieve a high 11.
So, I'll be replacing the clutch.
Will consider offers over $13k as is. The clutch will need replacing. It is still driveable but slips when under load.
Will also consider offers over $12k as above but without the rims. I will put the stockies on.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
