Apexi Power FC...Again???
Guest RedLineGTR
This is for one of my mates,
He has a r33 auto gtst,
i am still not convinced that the power fc will not work on a auto i havent seen any proof (hardcopy) except for what people have said, no details on apexi sites usa and japan (translated) nor in the vechicle compatibilty list. I know people say that the auto trans need the stock ecu to get some details, would anyone be willing to plug there power fc (with min mods) in my auto, i assume that the auto trans would just not work, but everything else would be fine. Anyone shedding some light on the issue, i have heard there might be some development on the auto soarers but nothing decent.
Thanks
Thanks
https://www.sau.com.au/forums/topic/12368-apexi-power-fcagain/
Hi RedLineGTR, what I know.....
* The Auto ECU gets the road speed signal from the Engine ECU
* The Auto ECU gets the engine RPM signal from the Engine ECU
* The Auto ECU gets the throttle position signal from the Engine ECU
* The Auto ECU gets the engine load signal (fuel map position) from the Engine ECU
* The Auto ECU gets the engine water temperature signal from the Engine ECU
* These output signals are not in the same format as the input signals from the sensors themselves
* A Power FC does not output these signals
What I can deduce from what I know....
- The Auto ECU will not know the road speed, therefore it will not know when to change gear
- The Auto ECU will not know the engine RPM, therefore it will not know when to change gear
- The Auto ECU will not know the engine loading, therefore it will not know when to lock up the torque converter
- The Auto ECU will not know when the engine is not up to operating temperature (too cold), therefore it will allow too high an engine RPM.
Sorry, but I have no knowledge of how a Microtech or a Link sends their output signals to the Auto ECU.
What I would do...........
I would wire up the Power FC as a piggy back, such that it and the standard ECU received all of the input signals. But only the PFC ran the engine (ignition, injectors and boost control). That way the Auto ECU would still get the correct output signals from the Standard Engine ECU and the PFC would control the engine.
Hope that makes sense.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
