The above is from my old S15, but compatible with Nissan all PFCs of the same era.
Cord is shortened (now approx 1 meter long) and a new plug has been fitted. Otherwise in good working order and no scratches, no fading LCD screen etc
As there are a couple of different firmware versions of the Nissan HC, best to check with Apexi first.
Can COD for $220.
https://www.sau.com.au/forums/topic/12506-apexi-pfc-hand-controller-200/
Originally posted by Gav
Details:
Model Number : 415-X001
Serial : FCC3 010-00806
Working  well with new plug but shorter (80cm) cord.
just a quick question, why it's shorter and has a new plug? if it's in working order and you accept the offer then consider it's sold..
check your pm..
Should have explained why the shorter plug.
When I wrote off my S15, I couldn't get access to the plug - therefore had to cut the cord.
No damage what so ever to the HC, and I have tested it with the new plug on. Also easy to make up extension cord if needed using data cable and mini DIN 6 plugs available from Jaycar for a couple of bucks.
Only reason I'm selling is that it isn't compatible with the very old PFC that I have in my GTR.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
