these seats and rails were originally out of a fresh import gtr32 - the owner was quite big and didn't fit. For my s15 (and all silvias/180s), one mounting point was approx. 3cm too short so that bracket was cut off and a new plate welded on by a professional. To have this fit skylines again all you need to do is drill a hole approx. 3cm in, no welding required.
the seats have no branding - choosen because i didn't want to have a big bride/sparco/recaro logo that say "steal me!"
the harnesses can fit with no modifications; if you want to run with the optional 5th and 6th point (that go around your crotch area) then you will need to find a mounting point below the seat.
https://www.sau.com.au/forums/topic/125583-sold/#findComment-2319745
Any chance of getting some more photos of the seats (front, side and back) in full detail?
Also, I have a coupe; how is this going to affect people climbing into the back as they're fixed buckets
https://www.sau.com.au/forums/topic/125583-sold/#findComment-2319754
  • 1 month later...
i will sell the drivers side seperately:
drivers side bucket + rail = $550
1 x 3" harness = $250
together = $750
IIRC the A31 rails are the same as R32/33/34 rails, so if i do remmeber correctly the rails will fit your A31 :(
Edited by _Wing_
https://www.sau.com.au/forums/topic/125583-sold/#findComment-2447004
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
