Hi,
Selling my skyline. it's a 94 model R33 GTS-T.
Car is stock standard, except for boost controller, turbo timer.
Tyres are 18" Low profiles, 235 fronts and 265 rear. Tyres are brand new.
Includes skyline mats, white dials on dash.
Boost runs on 9 standard and 10 after 4K rpm. Engine is extremely smooth.
Rego till March 2007, so over 8 months left.
Brand new front bumper, front lights, and grill.
car comes with a Viper alarm, 6 speaker Stereo.
Car is in very good condition as you can see from the pics, serviced every 5K. Nothing wrong with the car and only selling due to starting a business and need $$.
Asking for 13,500 ono (Will also consider swap for a van. )
I'm in Burwood area in Sydney.
Edited by kgangulw
why the new front bumper, foggies and grill???
accident histroy?
kays on car?
i have had this car for around 3 months only.(reason for sale, see above :) )
just before i got it someone knocked the front bumper of the car. nothing major at all. i looked at the dent before purchase and it was a fender bender basically. so the previous owner took it to his known panel beater/mechanic and since he knows the guy managed to get all that changed new through insurance....so nothing serious and basically it's a totally new front.
no other history of accidents. 131K odd at the moment on milleage.
thanks
Edited by kgangulw
thanks for the offer, but i'm only looking at cash at the moment. cheers.
Just what Im after!..BUT Im up on the Sunny Coast :action-smiley-069: ...and new to Oz so,how do things work?? give me a shout if any ideas .. [email protected] Ta!
Just what Im after!..BUT Im up on the Sunny Coast :) ...and new to Oz so,how do things work?? give me a shout if any ideas .. [email protected] Ta!
well taking a vehicle interstate aint that hard. you could of course fly & drive it back if u want to :) but arranging a courier would cost around $500 to take it from my place to yours. cheers
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
