carrillo's just seem a huge step up... i mean there's the 350rwkw and then there's like the carrillo's at 600rwkw... we need to find a 450rwkw rod. 350rwkw is easy to reach with a 3lt block and 450 is a happy medium, high enough power to be very reliable, but not so high that you are spending mega bucks
  • Replies 53
yeah i'm interested in the chevy ones too... i think that carillo rods are a bit beyond what i'm aiming for. I'm going for plenty of low-mid range power rather than all out topend. And once you pass the 320rwkw or so, the gearbox and other parts start to need looking at and i can't afford to do that!
Ah well Im aiming for 450rwkw at arounf 1.0-1.2 bar, If i get power hungry I want to make sure I done need to gringe every time I give the car a boot full, so Carrillos are the way I am going besides at around $1100 + machinng which is around $600 your not far off $2,400 for the carrillos, and if you do ever need to rebuild you can just buy one carrillo not 8!!!
The 2.5, 2.6 and 3.0 rods are all different in length. You will need to decide what capacity you want the 3.0 will make the same power at lower rpm and it will tend to last longer. If you go 3 litre then I assume as you, me and GiHOr33 will want RB30 Carrillos we will get a fair discount
Jordan
Update: Ive was given a hint. I found Oliver rods they said that they would suit a supercharged small block making 1100HP at 8,200 rpm. This is the same cylinder presure as a RB30/31 making 750/800Hp so hence they say these will do they are $125 US a rod which makes a set $1,500 Australian, allot cheaper than Carrillo what i want to know is how good they are, maching to make them suit will cost around $400 i guess so $1900 all up
Sydnekid or anyone else know about these rods and how good they are???
GR8NES/700
Hi GR8NES, what do I know about Oliver...........
* Oliver make good stuff, been around a long time
* used a lot in Nascar
* the rods are "I" beam
* they come standard with ARP rod bolts
* I think it's Trust that sell rebadged Oliver rods (and charge twice as much)
* they make forged and billet rods in three weights, standard, lightweight and super lightweight
* a set of 6 light weight, forged "I" beam, unmachined rods with 7/16 ARP 8740 rod bolts should be around $A1200 plus freight
* for about $A15 per rod extra you can upgrade to the ARP 2000 3/8 rod bolts
* my personal preference is their standard weight, billet, "I" beam, unmachined rod with 7/16 ARP 8740 rod bolts. Used them in a couple of Chevy speedway engines, no problems.
Never used them in a Skyline engine, but no reason why they would not be OK for the job.
Hope that helps.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
