bar is a measurement of pressure, just like psi.
Just enjoy your car for a while. Leave the turbo side of things alone for now. You have an R34 dude seriously! I'd swap my 180 for it in an instant! There is more to life than boost...
  • Replies 164
OI...Back on topic here.
Course you can park with us squizz :P you can park right beside me!
What if we do get down to the Gold Coast around 8ish. I'll probably be coming home early that night because of the dyno day the next day. So maybe starting earlier is a better idea. We can have dinner at yatala pies before hand!
This is boostcruising's dyno day.... Hang on I'm getting confused.
Let me work out the dates. We are thinking of having this cruise on the easter weekend yeah? So thats the 18th - 21st April. The saturday night is the 19th April. That's the night were looking at right?
The dyno day is.... *drum roll* oops sorry. May bad. It's not till the next weekend (the 26th April)...
So No.. I wont have to come home early*YAY*
So. The night we are looking at is the 19th April. Its a Saturday. Will everyone thats coming to brisbane be here for the drive?
Ok. heres a general idea of what we could do. i havent really put times in other than the time we should be at bwcp, this is because the carpark tends to fill up pretty quickly after 8pm, by 9 its pretty full usually and by 11 well its nigh impossible. so here we go....
saturday night cruise to bwcp
brisbane people meet at springwood in the crazy clarks carpark which is just up the road from the springwood maccas (brisbane people should know where im talkin about)
leave there at a pre determined time and head down to yatala to stop at the pie shop for some dinner, of course those who need fuel can pop on over to the bp and fill up, (and MRE can get some nandos chicken :P)
leave yatala pies and head down to the broadwater carpark to be there around 8pm so we are all parked in a bay close to the entry so people can look at our cars in all their glory :P
ok, goldcoasters some of you may not want to head to yatala to meet up with the group, so if yas need a staging point beforehand let me know and ill come up with something, otherwise the main point is to be at the bwcp by 8pm so we are all together and parked near each other, that way those who havent met each other before can have a chance to meet each other.
any ideas put em foward, lets try to make this happen as best we can so no one misses out :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
