Ok. Price is now $10500 with REGO and RWC, rego is due on NOV 22 and RWC expires on NOV 9.
I dont think Id let the car go for less than $10g.
All offers anyone make will still include RWC/Spares etc.
https://www.sau.com.au/forums/topic/131922-sold/page/2/#findComment-2612060
I hear you Hender! I think because people see its cheap and then think that I want to give it away! Cant import them for really less than $9g. And thats stock or close enough!
Problem is so many on the market! Yes P-plate laws make it hard.
https://www.sau.com.au/forums/topic/131922-sold/page/2/#findComment-2612163
