hey all,
was wondering if anyone knows of a service agent in perth who can look at my hks evc boost controller. the problem with it is that it won't hold a boost level - when set at 1.0 bar it fluctuates between 2 and 8 psi - measured on a dyno and on my boost guage.
i've replaced the controller with a bleed valve but spikes above 14 psi are not cool and neither is not having the cool readout on the hks..
any suggestions/flaming/ baggin/constructive ideas very welcome!
https://www.sau.com.au/forums/topic/13274-help-broken-hks-evc/
Nah I replied!
ITC hmmm ok ... well it works fine but started pinging on dyno run at Auto salon, so i was a bit upset but apparently it had happened to a few cars due to atmospheric pressure changes??
It does look pretty cool but i think i have to do another dyno tune with Brett to get it fine tuned for it... went there on Monday but was a bit busy... EVL R33 had apparently taken off his thumb in the door there!! and was in hospital!!! hope he is ok... his midnight purple r33 gtr is looking Sweeeeeet!! droolworthy!!
Doh - so you did.. :)
Not suprised you were upset. Wierd that it happened to a few cars. One would've thought that increased atmospheric pressure would mean more airflow - so maybe higher boost levels? That may have done it if you were running right on the wire at atmospheric? Maybe they should hold the dyno shootout outside next time?
Bugger for EVL R33 - hope he's ok. His car was lookin real nice.. :D
Well what made me take it off rather than check it is that the boost was all over the place.. was going up and down and in between.. all in one run on the dyno... wierd..
am going to hook it up again and try to calibrate it - this time properly cause i think it was a bit of a rush job before by a certain tuning house in perth to get the car to me in time.. if you saw the settings on the ITC you'd understand...
yeh a mechanic i know puts it in 4th gear at very low rpm and goes up a hill, it it pings a little then he calls it 'tuned' haha
but i suppose it makes sense cos thats a load that the car wouldnt normally experience. he says he never has a car ping under normal driving conditions if he sets it like that.
i prefer the more traditional methods but hey
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
