More Details -
http://www.boostcruising.com/forums/index....howtopic=158727
LINK UPDATED TO NEW ORGANISED CRUISE
Though we usually keep away from boostcruising, I think the cause behind this cruise is enough to atleast dismis any wrong thoughts of boostcruising for this one event and to atleast pay respect to the man who showed the world what an real Australian is.
The people behind the scenes of this cruise will also be taking donations which are goin towards 'Wildlife Warriors' thing that Steve Irwin has setup.
https://www.sau.com.au/forums/topic/133301-steve-irwin-cruise-on-15th-oct-2006/
I read the whole thread and I feel sooooooo much better about our forums now. I hope everyone realises that the Zoo will be packed for about the next 6 months or so. I'm all for doing something for Steve Irwin's memory, but there may be alternatives to cramming into his zoo.
Agreed Australia zoo is always packed before he died so now it will be chaos
