Regretful sale-moving
Nissan r32 gts-t type M Manual gun metal grey 92-93 spec (late 92 model)
This is an A1 example of an r32 not a ratty accident repaired car.
Only aussie owner.Imported 3 years ago personally.
Positives:
Engine idle's like a lexus,never thrashed,NEVER driven hard.Yes i drive like an old man... :ermm:post-21850-1157596097.jpgpost-21850-1157596553.jpg
My mates S15 engine sounds like a truck compared to mine!
Mods done in japan:
HKS pod filter
Cat back exhaust and top of the line muffler.(forgot the weird japanese brand)
Genuine Full GTR bodykit including rear wing-not a crappy imitation bar
GTS rear pods
Dark window tints
Raybrig fog lights with remote control!
Mods done here:
Full Tein hr coilovers
Dump pipe
High flow cat
Front sway bar
Front adjustable castor arms
5 spoke rare 17'' rims: a-tech monoblocks with falken alpha rs tyres made in japan
Brand new 2 month old heavy duty clutch exeedy
Brand new slave cylinder (clutch)
Brand new master cylinder (clutch)
New timing belt done at 108000kms
New spark plugs
New water pump at same time.
New speedo cable
New optima dry cell battery 3 months ago
Pro sound system install
Machined front discs
Bendix pro pads front,and rear
All electronics and lights etc work flawlessly
Nismo gear shifter
Projector front headlights-easily converted to xenon
Japanese seat belt extension arm-ultra rare!
Had done 90000kms when arrived.Now with 128000 Genuine kms
Always use 98 shell optimax
Allways used NISSAN 7.5W 30W oil and oil filter
Just serviced.
New airconditioner r34a gas and pipes/condenser
Full imobiliser with keyless entry tracker
Recipts to back up.
Negitives:
Small stone chips on front bar ( barley noticeable)
One of the best examples of a 32 gtst (if i do say so myself)
Asking 15,000 O.N.O
Genuine offers and intersest welcome,NO TEST PILOTS or tyre kickers,i dont have the time or insurance cover for this.Just give me a call to arrange a time.Details in post below.
Edited by cookie--monster
https://www.sau.com.au/forums/topic/133323-sold/
sure has...i will be renewing it in late december...if i still have it by then-i just put it on car sales and have had a very intrested buyer.i put the price down too.
will take off rims and stereo to lower it further still if needed.
https://www.sau.com.au/forums/topic/133323-sold/#findComment-2583252
