just thought i would refresh this ad to see if i can drum up a buyer.
1996 nissan RS4 awd rb25 powered wagon.
standard features include-
black factory leather
electric EVERYTHING!!!
climate air
atessa awd(same as GTR)
all factory mats,rear mat and cargo blind
automatic
tow bar
NOW THE MODS.....................
GT35r garrett turbo
GCG high mount manifold
38mm Tial wastegate
hybrid front mount with custom piping
3" turboback exhaust
turbosmart super sonic BOV
turbosmart duel stage boost control
700cc injectors
walbro fuel pump
sard fuel reg
spitfire coils
grex head gasket
gates racing timing belt
ARP head bolts
big transmission cooler
shift kit in auto
HALTECH E11 ECU
350Z 18" track wheels
conplete brand new lowered suspension
roof mounted DVD player
240v inverter(playstation!!!!)
just tick over 90'000kms
serviced every 3000kms with castrol synthetic oil and genuine filters
$19'990ono may consider trades as im after a car for my girlfriend
JAY 0410477413 or 02 47245555.
Edited by R33stagea
https://www.sau.com.au/forums/topic/136378-sold/
  • 3 weeks later...
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
