FOR SALE IS A SET OF GTR CAMSHAFTS FROM AN R32 (IN/EX)
REASON FOR SALE IS UPGRADED ENGINE AND NO LONGER NEEDED
ARE IN IMMACULATE CONDITION
PRICE $100ono
PICKUP IN SYDNEY PREFERRED BUT WILL POST AT BUYERS EXPENSE
https://www.sau.com.au/forums/topic/136778-sold/
