So the other day when cleaning my car I noticed wires with loose ends under the drivers and passenger seats. Under the drivers seat, one comes from the seatbelt unit, the other comes from under the carpet, from who knows where. Someone on here said its for the warning light, but also possibly for the pre tensioners which I believe are a safety thing for crashes? In which case I would rather like to know where Im meant to plug all these wires into.
https://www.sau.com.au/forums/topic/139239-seatbelt-warning-light-plug/
So.... you have the seat-belt end, and the carpet end? But they are loose wires, no plug?
Sounds like some very spirited vacuuming or friends with big feet ripped the plug off or something? I don't know why anyone would remove the plug intentionally.
Mine has (from memory) about 3 wires in the harness? You just need to plug both ends together with the correct pin-out. They're probably the same coloured wires on both sides.
Out of curiousity, does your seatbelt light on the dash light up when the ignition is on, but the belt is not done up?
No light on the dash.
Theres 2 wires (the plug ends are still intact, they just need to be plugged into something)
One, with a white end I think, comes directly from the seat belt buckle and isnt plugged into anything. Another wire comes out from under the carpet under the seat, and I think has a brown end. I tried plugging the white into the brown but they dont match so they are 2 different things.
  • 1 month later...
the buckle on your seat has a lead which then runs to the floor which is your seat belt warning light. When the car is complied, they are fitted with new belts, so the old seatbelt warning system is no longer effective, You need to get the old seat buckle which has the plug attached to it.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
