Buying R34
Originally posted by nismoR34
I am guessing he scammed a higher rating when he 1st took out insurance [like me :D] Or he was listed on his parents insurance during L's...maybe...
This is normal. I bludged 60% ncb off my olds as well but of course, phuqqed it up the wall with my colourful driving record.
T.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-299468
Kenshin,
>how much the rego? cuz thats the only cost we gotta pay if we >buy from dealer and i know nothin abt it, since this is my first >time buyin a car =( very sad case i know
The dealers usually give you 3 month registration. You do however have to pay stamp duty of 3% of the TOTAL Value of the car to the rta because it is a used car and trading hands. Ie if you buy privately its the same thing hence ppl on the sheet they bought it for $X thousands less to save on this cost.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-321407
Guest kenshin
what rate will u give regarding to the crime, chances and damages on r34 by some ppl out there
say the rating will be 1-5, the higher the rating is the higher chances and times that have already happened.
cuz i heard that mazda rx7 is seriously targeted by some ppl, whether they intend to steal the car or a part of it or damage it on purpose.
https://www.sau.com.au/forums/topic/14059-buying-r34/page/2/#findComment-340800
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
