velvet smoked colour 235/40/18 %90 tread all around...sp3000 sport dunlops soft compound expensive trye... wheels n tyres was brought togther 7 months ago used for 5000kms..excllent condition
$1500
Cheers,
https://www.sau.com.au/forums/topic/145736-velvet-smoked-colour-235s/
