hey ..
PSP with tony hawk. ridge racer and marvel heros games. charger, normal little sof cover thing that came with it
like new, hardly ever used
$350 ono
PS2 with a bunch of games.. 2 controllers.. well 3 but one doesnt always work.
$300
I will list the actuall ps2 games whne I get home.
pick up from richmond or baulkham hills on the weekend or early afternoon from richmond.
u can also pick up from st leonards any time usually from 5pm - 2 am :D
ill post pics as well if you want
https://www.sau.com.au/forums/topic/146404-psp-and-ps2/
ok..
games
GTA:Liberty City Stories
Tony Hawk Pro Skater 3
Tony Hawk Pros Skater 4
BackYard Wrestling: Don't try this at home
GTA: Vice City
ManHunt
Auto Modellista
Midnight Club
and a 8mb memory card
I might have a couple more laying around but im not sure.. ill have a look later
https://www.sau.com.au/forums/topic/146404-psp-and-ps2/#findComment-2737172
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
