Poll
26 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 49
Posted Images
yeah i was up there just before dark, saw a few lines and one rex on the side of the road but didnt stop. drop around a bit then took the long way home via basket range:) geez i love the gtr with lots of power:) entry into some 35k tight corners at 60+ exit 100+
Yeh that was us, i was in the rex....
its not just GTR's that do that :(
I need a decent diff.. Second gear out of any corner is just instant wheel spin.
Third isn't too bad but still tends to get a little hairy and spin up as it approaches 3.5-4k.
On that note what's the one you have laying around like Matt? Still fairly tight how many km's? What would u want for it?
Bl4ck32 is using mine to get through regency so it may be a good time to throw another in.
