Guys i bought a new speedo cable. Coz that stupid plastic piece has broken. So how do u replace it? anyone got like instructions step by step on how to do it? i got the speedo cluster out....so thats where im up to..
i seriously got no clue on where to go to now...so instructions anyone?
CHEERS BOYS!!
https://www.sau.com.au/forums/topic/149896-replacing-speedo-cable-in-32-gtst/
guys i didnt realise how straight forward it was to install a speedo cable. Only thing is that there are a few cables underneath that get in the way of the firewall cover and makes it difficlt to get the cable around.
thanks boys
yeah just be patient when uyr under the car and feeding the cable and plate through the pipes that ar allready under the car and GET IN THE WAY!! have two people aswell heaps easier, other snappiung the cable will be much more likely.
simple as:
*undoing the cable from the back of the gear box
*unscrewing 3 screws on the plate that is mounted righthand side of the engine bay bout half way up the firewall.
* make sure its been disconnected from the speedo
*and fgeed it from top down through the plastic tube out the firewall
*(just reverse the proces when putting it back in)
TIP when putting the cable back in, get sum1 to feed down from the top of the engine to you when ur under the car, at the same time, guide it through the stupid pipes that get in the way!! BE PATIENT AND HAVE FUN!!! HAHAHAHA
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
