1999 Mitsubishi Lancer MR Coupe 5 Speed Manual 96,000kms
Only the best went into this car as you will see below. The engine has been rebuilt to handle boost up to 14psi which can pump up to 190kw. Always well maintained, garaged and looked after. Had just been serviced and will pay for 1 year rego.
Comes tested with engineering certificates so every single mod is road worthy and also no trouble from coppers concerning mods on this car.
Will trade for R34 coupe in tiptronic plus cash adjustment from me as to work and study status is not appropriate for this kind of car.
Price is definetely negotiable
Engine
- VF23 Turbo
- HKS Front Mount Intercooler
- Custom Manifold
- Custom Intercooler Piping
- Custom 3in Exhaust Piping
- Apexi N1 High Flow Exhaust
- 500cc Sard Fuel Injectors
- Bosch Fuel Pump
- Fuel Pressure Regulator
- Microtech Computer
- K&N Air Filter
- Blitz Boost Controller
- Blitz Turbo Timer
Exterior
- Vertex Front Bar
- Vertex Side Skirts
- Vertex Rear Bar
- Respray in Metallic BMW Black
- Evo IV Rear Fog Lamps
- Narvara Headlights
- Imtec Wipers
Interior
- Recaro Front Seats
- Full Tan Leather Retrim
- Momo Steering Wheel
- Razo Gear Knob
- Ralliart Electronic Light Up Door Sills
- Boost Gauge
- Voltage Gauge
- Oil Pressure Guage
Drivetrain
- Heavy Duty Brass Button Clutch
- Strengthened Evo Gearbox
- LSD
Suspension and Brakes
- Bilstein Fully Adjustable Coilover Suspension
- Upgraded Brake System with Slotted Rotor Discs and Bendix Pads (Front)
- Strut Bar
Wheels
- 18 x 7.5 Linea Sport Racing Wheels
- BF Goodrich Semi Slicks (Front)
- Nangkangs (Rear)
Stereo
- Alpine 9835 Head Unit
- JL Audio Splits (Front)
- Kenwoods (Rear)
- Kenwood 2 Channel Amplifier
$22,000 ono
please call me on 0410 403 836 to arrange an inspection or for any questions.
open to all genuine offers
Edited by GMan
https://www.sau.com.au/forums/topic/150203-lancer-price-droppedurgent-18k/
where is that sticker from? I want it,not the godspeed the full drifta one
Any internal work on the motor?how many k's since conversion,
Is this 4wd ?
5 stud wheels or 4
cheers
Edited by turbohectics
Is this 4wd ?
5 stud wheels or 4
cheers
yea vinyls from bodyform coz they did most of the styling mods which included the retrim, respray, bodykit etc...
20,000kms since rebiuld, still front wheel drive so it shames most of the rears :D
i think its still 4 stud and guards have been expanded to accomodate 19"...also roadworthy now ;)
more pics here...
^^as you can see very clean car and always well maintained
any genuine offers considered...would like to trade for something auto coz jus had surgery in left leg and not feeling too stable..pref r34 but others are welcome
  • 3 weeks later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
