Hi guys.. Im looking for a left side headlight for my R34 GTT. I was told that you guys can help me, so please if you have 1 for sale or if you know someone that is selling 1 please let me know and how much roughly im looking at. I'd be realy thankful to you guys
https://www.sau.com.au/forums/topic/151543-r34-headlight/
guys i'm realy struggling trying to get this light so please if any1 knows anything bout where to get it from let me know ASAP please. I just can't sit back and see my car the way it is.
https://www.sau.com.au/forums/topic/151543-r34-headlight/#findComment-2824073
Like comparing the sun to your torch...
O....k didn't know there was that much difference anyways thanx guys 2moro I'll try to contact people in QLD n VIC also a couple of ppl in the US
https://www.sau.com.au/forums/topic/151543-r34-headlight/#findComment-2825484
sorry fella I have a passenger non xenon
Hi I hope you still have that non exnon headlight. I didn't know what was the difference between the twob :) , I went to see some ppl who supply spare parts today and they said that my lights are not xenon. It just says Xenon on the fitting but the actual lights are not xenon :) so if you still have that fitting and you still wana sell it please contact me on 0413 404 661 and that will be very much appreciated
https://www.sau.com.au/forums/topic/151543-r34-headlight/#findComment-2827889
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
