hey guys
lately my cefiro (rb25det) has had an idle rough as guts bounced round 300>900 rpm so i put threw injector cleaner n that and that did nothing (bout 4 months ago)
but earlier this week i put another one in for some reason and im threw 1/4 of my tank and now my revs sit about 1200rpm, still bounce a little 800>1200rpm and i fiddled with my idle control n it doesnt seem to change it at all.. :(
im just wondering if this cleaner did its job or is there something else that could be going on?
it feels like i just started it up but all day, could it be running cold start non stop? its used more fuel than usual too i think
thanks for any light you may shed
Jarryd
Should have cleanned your AAC value first if you got idle issues..
But cleaning the injectors with the cleaner shouldnt have casued any problems at all. .
Since you played around with your screw this might have affected it..
Theres a great tut in the tut section on cleaning the aav value.. give that a try maybe??
yeh iv read that top to bottom and it looks good, just havnt had much time to do anything really, i have high dependence on my car as its my daily.. i messed with the screw only this morning after 2 days of this high idle so i dont think that has much to do with it.
if it helps or matters i took my boost controller out day before i put the cleaner in as i dont like running high boost in summer
thanks
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
