Just wanted to check with other regular importers:
Has anyone else been having a hard time with Melbourne AQIS?
It seems every car that i have sent to Melbourne has been "contaminated" and requires quarantine cleaning.
Its not cheap either at almost $200 per car. :(
I have never had a problem with AQIS at any other port, so why is Melbourne so fussy?
I have used the same japanese supplier all along, so its not like the quality of the cars/condition should influence this.
https://www.sau.com.au/forums/topic/152469-aqis-inspections/
lol
Sydney was / has been pretty much the same in my experience and talking to some RAWS. First car I ever imported passed first go and the customs broker I used was surprised when he heard that. Didn't really understand what he meant until cars 2&3 came through :(
lol
I used to send all my cars to adelaide and never had a problem here.
I've started sending them to melbourne and every car has been "contaminated" I've sent one to sydney before and didnt have problem there either.
I thought it might just be a Melbourne thing
I suppose it is an easy revenue raiser for the government, as most importers will just want to see their cars out of the port to avoid storage fees.
I've thought about disputing this before, but considering how steep storage fees are.... the port is assured of revenue one way or another! :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
